Revit to GIS gdb
  • January 15, 2018
  • 129 views
Hi! since i do not have the extension of data interoperability extension, therefore, i hope to transform the file into .gdb to load the model into ArcGIS. May I know whether it is possible and if yes, how it works?
Thank you so much!!!
trentatsafe
  • January 15, 2018
Hello @wingszet807,
Here are some links that should help get you started for your Revit to GDB translation.
FME Exporter for Revit: https://knowledge.safe.com/articles/597/how-to-use-fme-exporter-for-revit.html
GIS and BIM webinar(contains a sample workspace that may help give you an idea) - while this webinar does contain some interoperability aspects, it should apply to FME as well: https://www.safe.com/webinars/how-to-create-gis-and-bim-interoperability/
IFC to GDB Q&A; post: https://knowledge.safe.com/questions/58594/ifc-to-filegeodatabase-multipart-feature-class.html
-There is an example workspace in this link posted by DaveAtSafe that should give you an idea of what a Revit to Geodatabase workspace will look like at the basic level.
I hope that helps.
