Mosaicing ECW without degradation
  • Jun 5, 2013 7:14 AM UTC
  • 5 replies
  • 66 views
Hello.
I'm trying to mosaic a large dataset (50GB/25000 files) of ECW-files into 17 mosaics.
One of the problems I encounter is the fact that the mosics are degraded compared to the orginal ECW files, which is of course unfortunate.
Any ideas on how I may resolve this problem?
fmelizard
Forum|alt.badge.img+22
  • Jun 5, 2013 7:26 AM UTC
This is usually caused by  the compression rate on the writer side ( see format parameters > compress by percentage) and the input data format.
I would try to lower the compression rate and see if it results in a less degreaded raster or another output format (jp2) which also support compression.
Hope this helps.
  • Jun 5, 2013 7:40 AM UTC
The original ECW files are already compressed, and even though compression rate is set to zero, artifacts still appears in the image. My initial guess is that it's not possible to merge ECW files in FME and write to ECW without degradation.
fmelizard
  • Jun 5, 2013 7:45 AM UTC
Compression always results in degradation, so you are right it was already degraded and will be degreaded after mosaiking.
  • Jun 5, 2013 7:52 AM UTC
So how can I create a lossless mosaic of the ECW files?
fmelizard
  • Jun 5, 2013 7:57 AM UTC
Write it to a format that doesnt compress , or set the compression to 0, this will result in bigger output features.
