Match List
  • Dec 13, 2017 1:22 PM UTC
  • 48 views
Hello Kind People!
I would like to create list of the final matches in my POI dataset. Currently I have table that contains pairs of duplicates (table on the left side). However, I would like to create final list, which says if POI where ID=1 is duplicate with POI (ID =2), and POI (ID=3) is also duplicate for POI (ID=2). Then it is obvious that POI (ID = 1) and POI (ID=3) also have to be duplicates.
I would like to ask if it is possible to create this kind of list in the FME, if yes which tester can be used to do it.
I will be grateful for all hints.
Forum|alt.badge.img+54
  • Dec 13, 2017 2:15 PM UTC
Have a look at the listcombiner on the fmehub, this will create groupings and a list containing all values for the group (in a list attribute called union{})
  • Dec 13, 2017 2:23 PM UTC
Thank you! I will try it!
