Is there a work instruction to sort a text file then export as a Excel? I have attached my current workbench and file as ZIP. I need to sort into 0-500, 501-2000, 2001+ sections.
  • Mar 16, 2022 1:40 AM UTC
  • 35 views
hrvoje
  • Mar 16, 2022 10:11 AM UTC
It will help you a lot if you read that file as CSV, rather than Text file, since your file is structured that way (Comma Separated). Make sure that you specify Field Names = 0 (for data without header).
You can also specify which columns are containing geometry information (lat, lon).
