Inspire Gml Administrative Boundaries- writing values from a list to gml
  • February 14, 2017
  • 11 views
I’m looking for some help please, if anyone can respond...
I’m using FME 2016 to transform data into INSPIRE gml for the administrativeBoundaries theme and I’m new to the world of xml.
I’ve looked at several examples on FME Knowledge for XMLTemplater but cannot get the values to write back as I want.
My source data is a geodatabase with linestring data containing references to their related polygons.
In FME I have concatenated these reference values for each ID , into one attribute, admUnit. Values are comma separated. I then use AttributeSplitter and ListExploder to expose the list, admUnit_list{}. The list length varies for different ID but never be empty.
AdministrativeBoundary.localID1admUnitRef1,Ref5,Ref6,Ref7admUnit_list{0}Ref1admUnit_list{1}Ref5admUnit_list{2}Ref6admUnit_list{3}Ref7 I want my final output as INSPIRE gml using the administrativeBoundary schema to resemble
<gml:featureMember>
<au:AdministrativeBoundary gml:id="ID1">
<au:admUnit xlink:href="Ref1"/>
<au:admUnit xlink:href="Ref5"/>
<au:admUnit xlink:href="Ref6"/>
<au:admUnit xlink:href="Ref7"/>
</au:AdministrativeBoundary>
</gml:featureMember>
I cannot get this output and due to a lack of experience with xml cannot work out what I am doing wrong...
I have tried two methods unsuccessfully
Method 1:
In xmlTemplater in the Root Template I have
for $admUnit in {fme:get-list-attribute("admUnit_list{}")}
return
<admUnit>{$admUnit}</admUnit>
I am writing the output from xmlTemplater to the attribute admUnit_result.
This gives me a one line output
admUnit_result (encoded: utf-8): <admUnit>Ref1</admUnit><admUnit>Ref5</admUnit><admUnit>Ref6</admUnit><admUnit>Ref7</admUnit>
I then use AttributeCopier to map admUnit_result to admUnit{0}.xlink_href
This writes to the gml file as
<gml:featureMember>
<au:AdministrativeBoundary gml:id="GB.NI.LPS.AU.L_1">
<au:admUnit xlink:href="<admUnit>Ref1</admUnit><admUnit>Ref5</
admUnit><admUnit>Ref6</admUnit><admUnit>Ref7</admUnit>"/>
1. How can I get this to resemble the gml output above where each value has a separate line?
2. How do I remove the < and > to give < and > respectively?
Method2:
In xmlTemplater if I set the root to
<root>
{fme:process-features("SUB")}
</root>
And the sub template to
<admUnit>
return
</admUnit>
The returned attribute, admUnit_result, shows empty values when viewed in Inspector.
1admUnitRef1,Ref5,Ref6,Ref7admUnit_list{0}Ref1admUnit_list{1}Ref5admUnit_list{2}Ref6admUnit_list{3}Ref7admUnit_resultadmUnit_result (encoded: utf-8): <root><admUnit></admUnit><admUnit></admUnit><admUnit></admUnit><admUnit></admUnit></root>
And in the gml file the admUnit element is similar with no values
<gml:featureMember>
<au:admUnit xlink:href="<root>
<admUnit>
</admUnit><admUnit>
</admUnit>
</root>"/>
How do I get the values to output?
Does anyone have a solution please?
Thanks.
Best answer by deanatsafe
I would strongly recommend using the INSPIRE GML writer rather than the XMLTemplater / Text File writer for writing or reading any EU INSPIRE data. We've invested a lot to fully support GML application schema based writing in order to better support complex schemas such as INSPIRE.
In this case, you need to select and add the INSPIRE writer and then select to add the AdministrativeBoundary destination feature type. In this feature type you will see admUnit{}.xlink_href. You will need to create a valid AdministrativeBoundary feature with the required properties such as inspireId etc. Then you will need to add a list to this feature called admUnit{}.xlink_href with values:
admUnit_list{0} = Ref1
admUnit_list{1} = Ref2
etc. For more info see: https://knowledge.safe.com/articles/775/inspire-gml-basic-writing-example.html
I believe you have a support case in our system so I will follow up there. If not, please contact us via http://www.safe.com/support/ for further assistance with this.
itay
Forum|alt.badge.img+17
  • February 14, 2017
If you are exploding the list, why use the list element in your xml templater? try using the attribute that contains the list element value after exploding the list.
  • February 15, 2017
@itay
the total number of attributes in the real list varies.
I was using xmlTemplater to perform iteration (or loop for each id) as the maximum number of values varies for each ID and the target gml requires a single entry.
I was attempting to write the values with the xml tags to an a single attribute so it would map easily to gml and the tags would give new lines.
Yes what you suggest works but it is cumbersome.
If I use the attribute created from exploding the list I need to enter a value range, so I need to know the maximum number of values in the list and then individually map these as the target gml attribute requests a single value.
This is creating empty entries in the gml as some Ids can have 2 attribute values, others have more.
In the data I also have a similar mapping to perform where the maximum number of options is large for each ID and I really do not want to have to do this mapping manually so if I can find a way to do iteration successfully it would be good.
Thanks for your answer.
itay
  • February 15, 2017
sacosni wrote:
@itay
I understand you better now, would it be possible to create the tag by concatenating the list elements (listConcatenator) into a new attribute and then use that attribute in the templater?
deanatsafe
  • March 27, 2017
