Import Survey123 information to FME Desktop
mr_fme
Forum|alt.badge.img+8
I need to extract information, responses from a survey123 form, into the FME Desktop, but as information there is no geographic information. How can I do this? It seems that the AGOL reader only reads feature services ... Thanks
drc43
Forum|alt.badge.img+11
  • April 23, 2020
Hi @mr_fme,
This should still work. I have a table with no geographic information hosted as a feature service, and I can read it into FME Desktop. I'm not sure if a survey123 form data comes in the same way, but the lack of geographic info shouldn't be the problem.
David
mr_fme
  • April 23, 2020
drc43 wrote:
Hi @mr_fme,
David
It´s a problem. I can read the other information, from survey123. But the other survey forms has at least one geographic feature. My problem is only forms. I guess that no feature service.
