How to stop startup/shutdown python from running
I've inhereted a workspace that comes with large chunks of Python that are run on startup/shutdown. I'm debugging the workspace and don't want them to run while I do so (it can't run in fact; I lack the necessary modules on my local machine). What's the best way to stop them running?
The best I can think of is a parameter (DEBUGGING), that I check, and if it's set I terminate the Python with:
     sys.exit()
Unfortunately, sys.exit() works by raising an exception (<SystemExit>), and FME interprets this as an ERROR level event and terminates the workspace.
So how can this be done short of deleting the python entirely? (my current solution)
Thanks,
Jonathan
  • May 20, 2015
Hi
what I use is to define a private paramet, e.g. called "DEBUG" that I set to either 1 or 0.
You can the surround you scripts or blocks with an if-statement, like:
if FME_MacroValues['DEBUG'] == '0':
    blablabla...
David
  • May 20, 2015
Hi David,
Thanks for the answer. That had occured to me but I was hoping for something more elegant.
It also occurs to me that something like this would be useful for the other startup/shutdown scripts (so SQL and TCL). I can't think of a way to do it for SQL at all.
Thanks,
Jonathan
