How to format DROP INDEX on GDB in Writer?
  • November 22, 2024
  • 36 views
whichwayisnorth
UPDATE 06/01/25:  It does indeed appear that once created, the index is automatically rebuilt on writing to the GDB with truncate existing.
Steps to recreate:
  • Add SQL statement to create attribute index after write
CREATE INDEX <name_INDEX> ON <table_name> (<attribute_name>)
  • Run the writer either to create new GDB or update existing GDB
  • Remove SQL statement
  • Continue to run writer as normal going forwards
Hi all,
This is driving me crazy trying to figure out. I have a GDB writer that builds an attribute index after write.
  • CREATE INDEX <name_INDEX> ON <table_name> (<attribute_name>)
Unbeknownst to me, each time I updated the data, an additional index was being created instead of overwritten which led to a bloated GDB and blown out write times. Note: The GDB table handling is set to truncate before write.
I first went to using the below statement, but I was unsuccessful.
  • ALTER INDEX <name_INDEX> ON <table_name> REBUILD
The next attempts were focussed on dropping the index before write and creating it anew afterwards.
My problem is that no matter which format I use, FME errors with ‘An invalid SQL statement was used’. I believe the issue could be with the INDEX parameter because it isn’t highlighted by the syntax highlighter and leaving it out provides a useful error:  'An expected Field was not found or could not be retrieved properly.
  • ALTER TABLE <table_name> DROP <name_INDEX>.
Here are the statement formats I’ve tried:
  • DROP INDEX <name_INDEX> ON <table_name>
  • DROP INDEX <name_INDEX> ON <table_name>(<attribute_name>)
  • DROP INDEX <name_INDEX> ON <table_name>.<attribute_name>
  • DROP INDEX <table_name>.<name_INDEX>
  • DROP INDEX <table_name>(<name_INDEX)
  • ALTER <table_name> DROP INDEX <name_INDEX>
    • including the above variations of ( ) and dot notation on the table name
  • I’ve also inserted IF EXISTS before and after the DROP INDEX command to no effect.
Does anyone know how I can achieve this? Any help is much appreciated.
whichwayisnorth
Maybe I’ve misunderstood attribute indices on FGDBs. Can anyone comment on whether I even need to rebuild the index when I truncate and repopulate the dataset, or do I only need to create the index once and each time I repopulate the FGDB, the index will be automatically rebuilt? Thanks.
nielsgerrits
Forum|alt.badge.img+54
I have no sample, but I would try to do this using a PythonCaller and arcpy. With the AI assistant in the PythonCaller it should be fairly easy to generate code for something like that.
whichwayisnorth
Thanks, I’ll give that a go if a user reports the speed of searching on the indexed attribute has worsened since last update.
