How to extrude shapefile and leave the centre hollow or transparent?
  • Mar 6, 2019 2:30 PM UTC
  • 52 views
I have got a shapefile and I only want to extrude the boundary layer and leave the centre hollow. Any tool to help me do this? If not is there a way to do this by calculating normal vector and then using appearance setter to make the centre transparent?
Forum|alt.badge.img+54
  • Mar 6, 2019 2:38 PM UTC
Presuming you are starting with a polygon, you could coerce to a line with the geometrycoercer and then extrude
What if it is not a polygon?
