How to change NaN to NoData?
  • Nov 17, 2014 8:45 PM UTC
  • 19 replies
  • 465 views
makt
I have a workflow where I am creating a raster using SurfaceModeler. As documented, this transformer may output some NaN values when using PLANAR interpolation. I indeed have a few cells that come out with a NaN value.
Β
Β
I am not certain what transformer can change my NaN values to NoData values (or any other values)?
Β
Β
I read through this article:Β http://blog.safe.com/2013/11/fmeevangelist119/
Β
and thought the NullAttributeMapper would be the answer, but it does not seem so.
Β
Β
Β
fmelizard
Forum|alt.badge.img+22
  • Nov 17, 2014 9:20 PM UTC
try the nodatasetter.
  • Nov 18, 2014 11:28 AM UTC
Β
Β
Β
Have you tried setting a preferable Nodata value to the "Output DEM Raster Nodata Value" parameter of the SurfaceModeller?
Β
Β
Takashi
fmelizard
  • Nov 18, 2014 7:05 PM UTC
Your error suggest that the value nan is not acceptable for a raster , try a numeric value such as 9999 or 0 for your nodata value.
makt
  • Nov 18, 2014 8:47 PM UTC
Hey Talashi - I already have a NoData value that is working, which is -32767.0, then I also have NaN cells as well so I don't think this setting is what I am looking for.
Β
Β
Itay - I think you are getting at the NoData value? My understanding of NaN is that is is not a number so it would not be 9999 or 0.
Β
Β
To simply my question: given that you have a 32 bit raster that has normal double values, has a NoData value set as -32767.0, and also has NaN values, what is the simplest way to make the NaN values into NoData values?
Β
Β
I have managed to do this but I'm not sure how efficient the process would be with larger datasets:
Β
I first convert the raster to points, then do a AttributeClassifier (passing only points that are "double") and then using NumericRasterizer to arrive back at a raster. This does the trick but is there a more efficient method?
Β
Β
Β
fmelizard
  • Nov 18, 2014 8:56 PM UTC
I would try the RasterCellValueReplacer, but I have my doubts about it....
makt
  • Nov 18, 2014 9:45 PM UTC
Just tried RasterCellValueReplacer, if I input 'nan' into the parameters, the output is a blank raster, so I don't think it is meant to replace a nan value.Β
  • Nov 18, 2014 10:30 PM UTC
It seems that "nan" is treated internally as a numeric value smaller than any valid value when comparing values.
Try the RasterCellValueReplacer with this setting:
Replace Values <=: -32767
New Value: -32767
makt
  • Nov 19, 2014 2:41 AM UTC
much more efficient !
Β
thanks to you both
  • Jun 16, 2019 3:15 AM UTC
New Value: -32767
An application. This workflow removes every "nan" point from the source point cloud feature.
pdorio
Forum|alt.badge.img+8
  • Sep 17, 2024 1:03 PM UTC
By me works well with raster with NaN nan or -nan Nodata value:
  1. RasterPropertyExtractor
  2. PointCloudCombiner with options: Extract NoData = No
  3. NumericRasterizer, set Cell Spacing and extent with the value extracted with RasterPropertyExtractor. Set your nodata value, example -9999
    Β
ekkischeffler
Forum|alt.badge.img+7
I’ve just tried this in FME 2025.1 but there doesn’t seem to be a real solution to this. I tried (various combinations of):
  • RasterCellValueReplacer (using the <= approach)
  • RasterBandNodataRemover
  • RasterExpressionEvaluator:Β @if(A[0]==nan,999,A[0])
  • RasterExpressionEvaluator:Β @if(A[0]<=-99,999,A[0])
  • RasterExpressionEvaluator:Β @if(@isnodata(A[0]),999,A[0])
  • RasterExpressionEvaluator:Β @if(@isnodata(A[0])==1,999,A[0])
  • RasterBandNodataSetter: Replace Cell Values - Yes
None of the above seems to handle the nan values. As a workaround I’ve tried:
  • RasterCellCoercer: Extract Nodata Values - No: this still extracts nan-cells! Need to combine this with a Tester afterwards to remove band values < -9999 (or similar)
  • PointCloudCombiner: Extract Nodata - No: this works
Both workarounds add a lot of unnecessary processing, especially with large raster files, and they would require rebuilding a raster if required.
Β
The only other option I can see is manipulating the raster geometry via a PythonCaller.
Β
Have I missed something - any other suggestions?
jkr_wrk
Forum|alt.badge.img+37
  • Jul 25, 2025 10:50 AM UTC
But what are the real values of the rastercell in binary? This could give a hint in the solution.
ekkischeffler
​@jkr_wrkΒ the IMG raster was created with -999 as nodata value and defined as such.
jkr_wrk
  • Jul 28, 2025 2:13 PM UTC
And where does the NaN come from?
The cell values are numeric/floating. Setting a value to -999 is done on the cell value and calling -999 NoData is done in the 'metadata’.
If you convert your service to a raster and click on a location that had a nan value does it appear as -999 or NoData or does it appear as some other value?
I probably just don’t understand the problem fully, so could be dumb questions.
ekkischeffler
​@jkr_wrkΒ thanks, I probably should have been clearer. No dumb questions!
The raster is being read directly via the ERDAS IMG reader. When I read the raster, the values in question come through as nan and do display as nan in the data inspector. I will need to manage the nodata values, ideally without conversion to vectors.
I do know that the original nodata value was -999 when the raster was written as IMG, plus the nodata value shows as -999 in the ArcPro raster metadata as well.
I was hoping the IMG reader would allow controlling the way nodata is being reproduced but I can’t see a relevant parameter there.
jkr_wrk
  • Jul 30, 2025 9:04 AM UTC
Did you try the nodata remover?
ekkischeffler
Yes, as per my post above.Β
jkr_wrk
  • Jul 31, 2025 7:56 AM UTC
I can’t think of any other solutions at this moment. Could you supply a small sample data? And your current not working transformers? Maybe someone else has an revelation when looking at the not working sample.
itsmatt
Forum|alt.badge.img+48
  • Jul 31, 2025 8:54 AM UTC
Are you able to extract all cells which are >=0 ORΒ <=0? I would expectΒ this should not include NaN?
