How do I use AppearanceSetter?
  • April 24, 2014
  • 202 views
fmelizard
Forum|alt.badge.img+22
I've got three different very simple 3D features that I want to export to a 3D PDF. That works.
But I now want to style each feature a different colour (based on an attribute).
But I can't figure out AppearanceSetter. There doesn't seem to be anything in the knowledge based newer than a very old FME-Evalangelist - http://blog.safe.com/2010/04/fmeevangelist58/  - and an article about what the Holder portion does - http://fmepedia.safe.com/articles/Samples_and_Demos/Using-the-HOLDER-ports-in-the-AppearanceSetter-transformer
All I want to do is set colours - no textures.
I feel the transformer is over-complex when I want to do something very simple (the help for the transformer doesn't live up to its name either). Suggestions welcome.
Thanks!
gio
Forum|alt.badge.img+15
  • April 24, 2014
You can use the PDFStyler for that.
 Or you can wirite colors to the relevant pdf- attributes.
Read the dpf reader/writer section in the
http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#pdf/Feature_Representation.htm
fmelizard
  • April 24, 2014
Hi Gio,
I ended up kind of figuring out AppearanceSetter - I used a testFilter to split by an attribute and then set up an AppearanceSetter for each one. Suboptimal I suspect but...
I'm not sure PDFStyler will do 3D stuff (it does work on the 2D stuff and in fact I only discovered it about 10 mins before your reply!).
Cheers,
Jonathan
gio
  • April 25, 2014
Ah, yes, i kinda missed that it was supposed to be for the 3D pdf.
I usually do that trough setting the relevant attributes like fme_color, fme_fill_color etc.
Rather then appearancestylers you can use a single conditional attribute creator.
 Or a valuerangemapper aslo very handy for colormapping.
