I am trying to specify the exact extent of my Raster DEM generated from LiDAR data. The lower left (origin) corner coordinates are 500000,5600000; 5m cell size; 500x500 cells, therefore upper right corner coordinates are 502500, 5602500. I can Specify Ground Extents in the NumericRasterizer, but not in the RasterDEMGenerator. Any suggestions on how to do this?
How can I set the raster extent in the RasterDEMGenerator? Similar to Specify Ground Extents in the NumericRasterizer?
Best answer by takashi
Hi @mikek, if you once transform the DEM raster from the RasterDEMGenerator into a point cloud with a PointCloudCombiner, you can then re-create a raster by a NumericeRasterizer with setting required ground extents, I think.
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
