Hello, I would like to know how can I convert GML data to geodatabse without missing my Information in attribute table
  • Oct 8, 2020 12:38 PM UTC
  • 11 replies
  • 82 views
 I created a work space with reader and writer and transformers but at the end when I get the result there are many fields which are "Null". I also used the template in the FME hub and got the same result. that would be great if any one helps me with this issue.
oscard
Forum|alt.badge.img+23
  • Oct 8, 2020 2:15 PM UTC
Would yo be able to post a sample of the data and your workspace?
Maybe there is something wrong with the attribute mapping, but I can't know for sure without taking a look at it.
  • Oct 9, 2020 6:09 AM UTC
Thank you for your Reply,
I attached a sample of data and my Workspace here.
  • Oct 9, 2020 6:10 AM UTC
It seems my workspace didnot upload. I uploaded my Workspace here again
oscard
  • Oct 9, 2020 6:47 AM UTC
As far as I can tell you are getting all those nulls because the source info doesn't have those values.
If you want to build a Dynamic process, you need to delete all the writer feature types except one, otherwise you are going to end with a lot of duplicates.
In the one you leave, remove all the User Attributes; because I guess you want the same ones as in the input.
  • Oct 9, 2020 6:58 AM UTC
But when I open the gml file in QGIS, I can see some values. I activated dynamic process because I wanted to be sure I will have all source info
  • Oct 9, 2020 7:03 AM UTC
I can also see the info with FME inspector but after converting all are "Null"
oscard
  • Oct 9, 2020 7:11 AM UTC
You are right! I'm not sure what is going on. Have you tried using the CityGML Reader instead of the GML one?
  • Oct 9, 2020 7:12 AM UTC
Should I remove USER Attributes in Output or Input? and actually it does not matter Dynamic or Manual one. I just want to have those info
  • Oct 9, 2020 7:21 AM UTC
Yes, I have tried both and I got the same result
oscard
  • Oct 9, 2020 7:34 AM UTC
In a Dynamic workspace, if you want the same attributes as in the input, you should delete the attributes in the Writer.
I honestly don't know what is going on. It should be simple, but I can't make it work. Sorry.
Maybe someone else has a better day than I
  • Oct 9, 2020 7:36 AM UTC
Thanks for your reply
