GPX Waypoint Labels
Hello...I've succeeded in converting an ArcGIS Online feature service into gpx waypoints, however, the waypoint labels are WPT001, WPT002, etc. How can these be labelled using an attribute from the source feature service?
Forum|alt.badge.img+49
The Waypoint feature type has a "name" attribute, you can direct a source attribute to this and that should do the trick.
  • June 2, 2016
Thanks @redgeographics...got it to work...clearly a rookie FME user question.
