GoCAD ts files
pat_uow
Hi FMErs,
Has anyone had any experience importing GoCAD ts files into FME using another reader type. It appears that GoCAD is not supported directly in FME, however the geometry of the object/s appear to be 3D triangulated surfaces ?
Thanks in advance
danilo_fme
Forum|alt.badge.img+41
  • July 17, 2018
Hi @pat_uow
Particularly, I did not work before with this format.
But, I checked here in Knowledge Center that there is a Idea to implement this format in the next versions from FME.
The link: Add 3D GOCAD/SKUA file format
If you want to share us a simple of your data to try it.
Thanks,
Danilo
pat_uow
  • July 18, 2018
danilo_fme wrote:
Hi @pat_uow
Thanks,
Danilo
Hi @danilo_fme,
The GoCAD ts source files are available from https://gsnsw.glassterra.com/?defaultview
Selecting any of the Sydney-Gunnedah basin faults and then "download selected" will get the zipped ts files.
danilo_fme
  • July 18, 2018
pat_uow wrote:
Hi @danilo_fme,
Hi @pat_uow
Thanks your data.
I did download and tried to open in FME Desktop 2018.1 but I didn't have sucess.
I suggest you to vote the Idea. https://knowledge.safe.com/content/idea/28707/add-3d-gocadskua-file-format.html
Thanks,
3d_ff
Forum|alt.badge.img+5
  • May 6, 2022
In 2022, to have a work around to be able to import Datamine, gOcad and Leapfrog 3D objects within FME to be able to automate queries and manipulations on these objects would be useful to many FME users to complete the link between 2D GIS and 3D spatial objects.
daraghatsafe
Hi @3d_ff​ thank you for your suggestion and for adding a comment to the idea that is posted here. Keep an eye on this idea for any further developments.
Regards, Daragh
