GOAL: Reduce multiline centerline with many branches to single, longest line
  • Oct 31, 2019 9:20 PM UTC
  • 7 replies
  • 141 views
jeaton
Participant
So, FME has this fabulous transformer, the "Center Line Replacer." But when you're trying to get the centerline of a lake, sometimes it doesn't work so well:
Now, I'm a reasonably smart dude, but I have yet been able to figure out how to get a single, longest distance line out of this net.
Does anyone know how?
Many thanks in advance!
Johnny
erik_jan
Forum|alt.badge.img+26
  • Oct 31, 2019 11:47 PM UTC
I would try using the ShortestPathFinder, using the start and end point of the desired line segment.
Hope this helps.
jeaton
Participant
  • Participant
  • Nov 1, 2019 12:15 AM UTC
Hope this helps.
I've tried shortest path finder, but I don't have clear start and end points. What I need to know is the length of every route across that network. It's... challenging, to say the least.
Forum|alt.badge.img+54
  • Nov 1, 2019 9:04 AM UTC
In this scenario, it's not clear exactly what outcome is desirable. Something like this?
jeaton
Participant
  • Participant
  • Nov 1, 2019 10:38 AM UTC
This is very close to what I am after, yes. The desired outcome is a line that can then be used to guide a label for the feature. So, ideally, the line would reach from one 'end' of the feature to the other, though sometimes, as in this example, there aren't clear 'ends'. A similarly problematic feature is Lac Manicouagan in Quebec, Canada, which is a round lake with a big island in the middle, though a longest route approach may work for that since the route could be infinite.
  • Nov 1, 2019 10:58 AM UTC
Something close to this can be achieved by taking all the dangling end points from the line produced by the centreline replacer, creating lines between all permutations of points, then sending these as from to lines into the shortest path finder, sending the original line as the network. You can then choose the longest of these lines.
jeaton
Participant
  • Participant
  • Nov 1, 2019 11:30 AM UTC
Would this be possible for multiple features, i.e. multiple networks? Would I have to set up some sort of loop? I have not used Shortest Path Finder much, so I am unfamiliar with its mechanism.
jeaton
Participant
  • Participant
  • Nov 1, 2019 8:05 PM UTC
This did help set me on the right path to finding what I needed to do. Thank you!
