Genereate new identity and make bind to it
Hi.
What is the best way to generate values for new numeric identy fields in Redshift which not exist in source structure of tables and bind this new values with other data?
For example there is table
IDPERSONTHING1JhonCar2AdamCar3JhonPen
I want to split this table into three tables:
1) PESRONS
IDPERSON1Jhon2Adam
2) THINGS
IDTHING1Car2Pen
3) LINKS
IDPERSON_IDTHING_ID111221312
So, I need to negerate ID for tables PESRONS and THINGS, and bind persons and things by this new identities in table LINKS.
How I can do that in FME desktop?
Thanks.
Forum|alt.badge.img+19
  • June 10, 2016
Hi @useytkaziev, maybe this is a plain way.
  1. Branch the data flow into two streams.
  2. On a stream, create 'PERSONS' features. AttributeRemover: remove 'THING' -> DuplicateFilter (called DuplicateRemover in FME 2015 and ealier) : remove duplicate 'PERSON' -> Counter: overwrite 'ID' with new 1-based sequential number.
  3. On another stream, create 'THINGS' features in the same way.
  4. FeatureMerger: merge the 'PERSONS' to the original features using 'PERSON' as the join key. Here you can add the prefix 'PERSON_' to attributes of 'PERSONS' features with the parameter setting for the FeatureMerger (Accumulation Mode: Prefix Supplier).
  5. FeatureMerger: merge the 'THINGS' to the features output from the Merged port of the first FeatureMerger using 'THING' as the join key, adding prefix 'THING_' to supplier attributes.
The features output from the Merged port of the second FeatureMerger are the 'LINKS' features.
Hi, takashi.
Thanks for your reply. I will try this method.
Forum|alt.badge.img+5
I wondered if I could do this any simpler, but I don't think so. The one thing I did have to be careful of, was to set a different Counter Name for each of the two Counter transformers. Other than that, Takashi's solution works like a charm.
I've attached the workspace I created below...
tablesplitter.fmw
  • June 13, 2016
As @mark2catsafe mentioned, there may not be any simpler way, but if you are familiar with SQL, the InlineQuerier could also be used effectively. e.g.
SQL Statements
1. Links
select a.ID as ID, b.ID as Person_ID, c.ID as Thing_ID
from Source as a
inner join Persons as b on b.Person = a.Person
inner join Things as c on c.Thing = a.Thing
order by a.ID
2. Persons
select ID, Person from Persons order by ID
3. Things
select ID, Thing from Things order by ID
