FME Can deal with registry data ? ex : HKEY_CURRENT_USER key and values data
  • 23 October 2017
  • 7 views
Useing FME desktop Can i read and write "HKEY_CURRENT_USER" data ?
I need Created the key at run time and set the value according i will read the parameter values.
Best answer by brianatsafe
Hi @kumarc,
You can use a python library with the PythonCaller to do this. For example, the WinReg Module has tools to access and edit the Windows Registry.
See:
https://docs.python.org/2/library/_winreg.html#module-_winreg
brianatsafe
Forum|alt.badge.img+11
  • October 23, 2017
Hi @kumarc,
See:
