Extending the read timeout in the SharePointOnlineConnector?
  • Aug 30, 2023 8:53 AM UTC
  • 236 views
peteralstorp
Forum|alt.badge.img+8
I read files from Sharepoint. Sometimes I can read all the files but other times (no obvious pattern) I get this error msg when reading the exact same files again:
`fme_rejection_message' has value `SharepointOnlineConnector: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='graph.microsoft.com', port=443): Read timed out. (read timeout=60)''
Can I somehow easily adjust the read timeout?
Best answer by topf
Depending on what FME version you are running it is either 20(?) or 60 seconds (from FME2020 supposedly), hardcoded.
See idea: https://community.safe.com/s/bridea/a0r4Q00000HbqrrQAB/sharepoint-reader-timeout-parameter
topf
  • Sep 8, 2023 11:14 AM UTC
peteralstorp
  • Sep 8, 2023 11:20 AM UTC
Thanks @Tobias Pfeifer​ !
