Creating a line between two Nodes
  • November 24, 2013
  • 6 views
Help!!!
I have an Attribute called 'GPS_Code' with values grouped like
CL10 ST
CL10 EL
CL2 ST
CL2 EL
CL8 ST
CL8 EL.........etc
I want to create a line string  between the ST and the EL but only for those with corresponding numbers.  So a line between CL10 ST and CL10 EL, for example.
Currently the result I'm gettting is lines joining willy nilly all over the place.
I am using StringSearcher
Attribute GPS_Code
Regular Expression:  ^(.+)(SL|EL)$
Matched Result Attribute: _matched_characters
Matched Pars Attribute: _matched_parts
with Sorter
_Matched_parts{0}         Alphabetic             Ascending
_matched_parts{1}        Alphabetic             Decending
and PointConnector
Connection Break Attrbutes: _matched_parts{0}
List Name:
Cheers,
          Shane
Forum|alt.badge.img+19
  • November 24, 2013
CL10 ST CL10 EL CL2 ST CL2 EL ...   If there are not typos, the regular expression should be: Regular Expression:  ^(.+)(ST|EL)$
In addition, if there always is a white space between front and back part of the code, the AttributeSplitter can be also used instead of the StringSearcher.
Takashi
  • November 25, 2013
typo :((
Thanks it worked :)
