Create line from single point and text
  • Nov 16, 2020 10:55 AM UTC
  • 82 views
ingalla
Forum|alt.badge.img+10
Hello
I need to create a polyline dataset based on a point dataset which contains a text string. The text attributes also contain the orientation.
As I have 1 point for each text feature how can I either :-
add another point at the end of the text string and then join the points together to create a polyline, or
can I just create a polyline directly from the text string for the correct length and orientation.
Any suggestions on how to achieve this would be welcome.
Thanks
  • Nov 16, 2020 11:04 AM UTC
I'm not quite sure I understand the details of your question, but if you use a VertexCreator to add a vertex to an existing point geometry, it will automatically be converted to a line.
