Convert serialized graphic to shape
  • April 22, 2015
  • 8 views
We have serialized graphic stored on our database and we need to covert it to shape file , I used geomotry replacer but none of geometry encoder works   . Below is the same code
        "stype": "solid",
        "ssize": 1,
        "sradius": 1,
        "scolor": 0,
        "stypename": "SFS",
        "salpha": 0.5,
        "garray": [
                "x": 54.36774826717463,
                "y": 24.45024020254503,
                "spatialReference": {
                    "wkid": 4326
                "x": 54.36831933781603,
                "y": 24.45027827392112,
                    "wkid": 4326
                "x": 54.36832885566005,
                "y": 24.449888042316164,
                    "wkid": 4326
                "x": 54.36780537423877,
                "y": 24.44987852447214,
                    "wkid": 4326
                    "wkid": 4326
        "swidth": 2,
        "scolorb": 0,
        "gtype": "P",
        "salphab": 0.5,
        "gsr": 4326,
        "initialExtent": {
            "xmin": 54.361133365578425,
            "ymin": 24.445633566037742,
            "xmax": 54.3794076261032,
            "ymax": 24.455446463225783,
                "wkid": 4326
        "stext": ""
        "stype": "solid",
        "ssize": 1,
        "sradius": 1,
        "scolor": 0,
        "stypename": "SFS",
        "salpha": 0.5,
        "garray": [
                "x": 54.36852873038455,
                "y": 24.450259238233073,
                    "wkid": 4326
                "x": 54.36917594377813,
                "y": 24.45030682745319,
                    "wkid": 4326
                "x": 54.36922353299825,
                "y": 24.44981189956398,
                    "wkid": 4326
                "x": 54.36860487313673,
                "y": 24.449802381719955,
                    "wkid": 4326
                    "wkid": 4326
        "swidth": 2,
        "scolorb": 0,
        "gtype": "P",
        "salphab": 0.5,
        "gsr": 4326,
        "initialExtent": {
                "wkid": 4326
        "stext": ""
  • April 23, 2015
there are several ways to serialize geometries with JSON, which one was used here?
If none of the standards schemas were used (ESRI or OGC), you might have to deserialize it yourself, using the JSON-Transformers in FME.
David
