Change log file name with FMEWorkspaceRunner
Hello. I am running workspaces using FME Python API and the class FMEWorkspaceRunner, where I am currently using the method runWithParameters.
I would like to know how can I change the Log file name (and path) when running the workspace in this way. I saw in the documentation that runWithParametersAndDirectives have an example about change the log name, but it is not clear for me.
Thanks.
Forum|alt.badge.img+21
  • December 6, 2016
Hi @diniz, the example described in the Python FME Objects API doc is not good. It seems to be C++ code and also be wrong :-(
Check this Python script snippet.
workspace = 'C:/tmp/your_workspace.fmw'
parameters = {'PARAM1':'VALUE1''PARAM2':'VALUE2'# pairs of parameter name and value
directives = {'LOG_FILENAME':'C:/tmp/out.log'# specify log file path
wr = fmeobjects.FMEWorkspaceRunner()
wr.runWithParametersAndDirectives(workspace, parameters, directives)
jamesadams
Forum|alt.badge.img+3
  • October 16, 2024
Thanks for sharing this. Took me some time to find a working example.
