Can I call a published FME workbench on FME Server using a .bat file?
raaaju1990
I have a workbench published on FME Server. Now, I need to call that workbench using .bat file and run it. Is that possible?
I have tied calling a local FME workbench using .bat file but never a published work bench from FME Server.
Thanks you.
  • April 3, 2019
As far as I know that isn't possible, you'll have to use the publishing wizard in FME Workbench to publish to FME Server.
You should consider voting for this idea:
https://knowledge.safe.com/content/idea/23653/fme-server-workspacetransformer-batched-publishing.html
raaaju1990
  • April 3, 2019
Actually, the workbench is already published. I just need to call the published workbench using a .bat file. Is that possible?
  • April 3, 2019
The easiest way to start a job on FME Server from a batch file is using the FMEServerConsole command line client:
https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/Interactive_Command-Line.htm
itay
Forum|alt.badge.img+17
  • April 3, 2019
IF you can do a GET in the batch to the published workspace, then I think I will work.
You can get the URL to your workspace from the FME Server UI.
