AUS gda 2020
  • February 4, 2018
  • 8 replies
  • 144 views
HI all, i am a bit lost and was hoping someone could help pint me in the right direction.
I am currently using fme 2017.1 and i have been tasked with updating some ascii to gda 2020 from gda94. I note that within the coordinate system gallery there is a parameter for Geodetic Datum of Australia 2020, Latitude-Longitude; Degrees LL-gda2020_fme
is this the conformal or conformal + distortion transformation grids? i am a bit lost with this.
I have copied the GDA94_GDA2020_conformal_and_distortion.gsb into my reporject>gridata>Australia folder but i cannot see it in my coordinate system gallery.
I feel that this should be a failry basic process to get this to display but i am not sure what i am doing wrong.
any help is very appeictive.
Best answer by paul.nalos
We added the conformal + distortion transformation grid to FME 2018.0 Build 18240. If you have anything earlier than that, FME will use the conformal transformation only.
Once you have a new-enough build, you can specify the transformation in the CsMapReprojector:
For additional details, see here: https://knowledge.safe.com/articles/44498/new-australian-national-datum-gda2020-support-with.html
paul.nalos
  • February 6, 2018
thejando
Forum|alt.badge.img+4
  • November 28, 2018
Thanks for the info @paulnalos
I have just installed FME 2018.1 build 18567.
So, if I leave the Transformation as <Auto>, which transformation grid will FME use? How do I know which transformation FME is using as Default.
For example, I am reprojecting from EPSG:28355 (GDA94 / MGA Zone 55) to EPSG: 7855 (GDA2020 / MGA Zone 55).
paul.nalos
  • November 28, 2018
The default is the conformal-only transformation.
That said, given the importance of getting this choice right, if you keep the "auto" choice, a warning is printed:
CS-MAP Reprojector: Using 'GDA94_to_GDA2020_conformal_only_7P_FME' for GDA94 <-> GDA2020. If you wish to use the other transformation instead, use a CsmapReprojector transformer and select that transformation explicitly. The choice between the two transformations is highly important for data quality. See the technical manual at http://www.icsm.gov.au/gda/tech.html for details
(The URL at the end of that message is no longer available. I'll have it changed to: http://www.icsm.gov.au/sites/default/files/GDA2020TechnicalManualV1.1.1.pdf
thejando
  • November 29, 2018
Do you know how to change which grid file FME uses by default?
No dramas if you don't know off the top of your head, I can contact FME support.
paul.nalos
  • November 30, 2018
If you have the default configuration (FME Workbench -> Tools -> FME Options... -> Default Paths -> Shared FME Folders -> <documents>/FME), then you can simply add a file to that folder (FME folder within Documents), with the following text:
GDA94|GDA2020|XFORM|FWD|GDA94_to_GDA2020_conformal_and_distortion_NTv2_Grid_FME
... this will change the default to the conformal + distortion grid.
The other default uses the following text in a different place:
GDA94|GDA2020|XFORM|FWD|GDA94_to_GDA2020_conformal_only_7P_FME
(but if you like the current, conformal-only, default, no need to take any action at all).
thejando
  • October 17, 2019
Hi @paulnalos I am following up on this almost a year later! Thank you for your help so far.
To reiterate... I want to force FME to use the conformal and distortion grid every time I reproject between GDA94 and GDA2020, and I don't want to have to manually add the CsmapReprojector transformer every time I do a reprojection. So in other words, I want to change the default transformation that FME uses from "conformal only" to "conformal and distortion".
I tried setting my Shared FME Folder to the Documents\\FME folder, and then created a text file (called MyTransformation.txt) in the FME folder containing the text that you suggested:
But this did not change the way FME did the reprojection.
I found a file called TransformationExceptions.db in the Reproject\\CsmapTransformationExceptions folder under the FME installation folder. Perhaps this is what you were referring to above when you said "The other default uses the following text in a different place"?
Anyhow, I opened the file in a text editor and modified the following line:
...to...
My testing has shown that this correctly changed the default FME transformation from "conformal only" to "conformal and distortion".
Can you confirm that I have done the right thing here?
paul.nalos
  • October 17, 2019
...to...
But it is not correct to place that file just inside <documents>/FME. You need to place it inside <documents>/FME/CsmapTransformationExceptions.
The change you made (to the equivalent directory within the FME install) is also good. However, it will be overwritten when you next install or upgrade FME.
thejando
  • October 22, 2019
@paulnalos your solution above worked for me.
Thank you again for your assistance.
