AttributeFileWriter and FME server
  • May 18, 2017
  • 107 views
trembathp
In have a file geodatabase table with 6.7M features. A v simplified workflow is:
  1. Initiate the workbench with a Creator
  2. Do some logic tests
  3. If conditions are met, load in features from the database, do some processing then write the results using a generic writer
  4. If conditions are not met, simply make a copy of the entire database using an AttributeFileReader to read the database and an AttributeFileWriter to write the copy
This works really well on the desktop but when I run it on FME server [data download service], (3) works fine but (4) will not work. I understand WHY it doesn't work (the data download service doesn't have an output dataset to write) but I can't figure out how I can fix it. Can anyone help? (The server version I'm using is 2015)
jdh
Forum|alt.badge.img+41
  • May 18, 2017
Why not use the File Copy writer? That will give you an output dataset for the data download service.
itay
Forum|alt.badge.img+19
  • May 18, 2017
I agree the FileCopy writer is the way to go, and to read the db I would use the FeatureReader.
trembathp
  • May 19, 2017
Thanks for your help. I think its getting me a bit further but I still can't get it to work on the server.
I've used a File Copy writer, tested it on the desktop - it works OK. I've then published to the server and it appears to run OK. I can't see any problems in the logs but when I download the results, it gives me an empty zip file.
As a test, I've created the simplest possible workbench which contains nothing except a creator, a parameter fetcher and a File Copy writer (attached). I get the same problem.
Any ideas?
