Assigning a value to roadnetwork at most 15 mile breaks along roads
  • Jun 19, 2020 3:04 PM UTC
  • 55 views
Hello,
I'm currently working on a road network of ~3000 miles and some roads can go for 100 miles+
I'm looking to assign a value if the roadname is the same and the accumulative distance is 15 miles at most.
So 1 road for example can be shown by 6 segments
0-3
3-10
10-14
14-20
20-28
28-35
In the scenario above I would like 0-14 in 1 group as it is below 15 miles, then 14-28 in the second group and 28-35 in the next group.
Currently a part of the workbench that works on assigning this is:
However the issue I'm coming across is after 15 since the accumulative number is beyond 15 but the sum of 2 segments may still be below 15 miles. I'm not sure how to reset it as a reset would assign the whole road the same value.
I'm a little stuck here and could really use some help
Best answer by ebygomm
If you had the cumulative distance you could assign a group using an arithmetic expression
@Evaluate(@ceil(@Value(cumulative)/15))
*use @floor instead of @ceil if you want the groups to start from 0
Forum|alt.badge.img+54
  • Jun 19, 2020 3:19 PM UTC
Thanks I was able to assign the correct identifier thanks to this.
