User Parameter for use in Attribute Filter
williams_s21
Forgive me for what is likely a very simple answer to this question, but I'm still rather new to FME.
I'm wanting to use a defined User Parameter (Type - Text) which will then inform my AttributeFilter transformer (where the user parameter directly corresponds to a specific field of the dataset being read by the AttributeFilter transformer). However, when I set the transformer parameters as per the screenshot below, I don't then get the expected output, i.e. the dataset filtered for that specific value.
Is there something I'm missing?
Thankyou for taking the time to read this post.
Best answer by dustin
Try using the TestFilter instead of the AttributeFilter.image
dustin
Forum|alt.badge.img+30
  • July 7, 2022
williams_s21
  • July 7, 2022
Thankyou ddbrocato. That works perfectly.
