Writing to Excel tables and formatting
sofia
Forum|alt.badge.img+5
Hi!
Does any one know of a good resource on formating FME output in excelfiles? I have, for example, an excel writer where I don't manage to get the rows that get written to land inside the table in my excel template. Instead the rows write themselves outside of the table, and then I have to go in manually to cut out and paste the rows into the table.
There are many other small things and fine tuning I would like to do with the way my excel file gets written. Another couple of formatting things I want to learn how to do are hiding columns, filtering on certain values (while making the data still available in the sheet) etc.
If you know of any, please recommend a good website,video or document where I can read more on these kinds of formatting tips and tricks!
danilo_fme
Forum|alt.badge.img+44
  • April 10, 2018
Hi @sofiamvalentin,
In Webinar section there is a important Topic about Tips for Automating Excel
With this Webinar is possible to do download the Workspaces used about in this Webinar.
I hope that this help you!
Thanks,
Danilo
sofia
  • April 10, 2018
danilo_fme wrote:
Hi @sofiamvalentin,
Thanks,
Danilo
Thank you, I will check the webinar out!
