the problem when i see data in pgadmin i cant perview data correct . however it is shown in fme inspector
fme2019.1
fme2019.1
Best answer by nielsgerrits
It's hard to understand what you are asking exactly, but I think the issue you have is you are writing to a generic geometry column. (Generic is multi geometry type, most GIS software can't handle this.) This is the default in the PostGIS Writer somehow. You can find it under Parameters... Uncheck "Create Generic Spatial Columns"
