Text character spacing
  • December 16, 2014
  • 18 views
Are there controls for the spacing of each character when using a process which involves labeller and text stroker?
For example I have a string "CA" , I would like to be able to set the distance between each character e.g 1.5m or 1m distance.
Thanks.
Best answer by david_r
look into the third-party transformer MapTextLabeller (http://fmepedia.safe.com/articles/Samples_and_Demos/Introduction-to-MapTextLabeller), it might be able to do it for you.
David
  • December 16, 2014
David
