Problem with "RasterCellCoercer"
Dear FME-Users,
I've a problem with "RasterCellCoercer", because this transformer don't write pixel values into an attribute.
It only works with "RasterToPolygonCoercer" (attribute "_label").
What I'm doing wrong?
Thnak you very much and best regards.
Konrad
Best answer by uba_kp
Both does not work @itay @jdh . The attribute "_con" is still empty.
jdh
Forum|alt.badge.img+28
  • April 27, 2017
The rasterCellCoercer outputs a list, rather than an attribute, so depending on which band(s) you want the value from you can use a ListIndexer or ListConcatenator
  • April 27, 2017
Thank you @jdh, but both transformers does not work. Do you've some more ideas?
jdh
  • April 27, 2017
What exactly do you mean by does not work, are they throwing errors or not doing anything? Can you post some sample data or the results of a logger attached to the RasterCellCoercer?
itay
Forum|alt.badge.img+17
  • April 27, 2017
could it be that you are using the table view in the Data Inspector? have a look at the result via the feature information window, the table view does not show lists and its elements.
  • April 27, 2017
I've added to screenshots, take a look to the attachement please.
  • April 27, 2017
No I used ArcMap instead of Data Inspector.
itay
  • April 27, 2017
You need to connect the ports of the transformer to the writer (they become green) to write the values.
jdh
  • April 27, 2017
The ListConcatenator needs to come after the RasterCellCoercer.
  • April 27, 2017
jdh
  • April 27, 2017
Did you change the parameter on the ListConcatenator to point to _band{}.value ?
  • April 27, 2017
I don't know what you mean. I've added a screenshot of this transformer already.
jdh
  • April 27, 2017
And in the screenshot you posted, you are concatenating a list called netcdf_data_variable.valid_range{}, which presumably is empty since _con is empty.
You need to concatenate the list that is produced by the RasterCellCoercer which is called _band{}.value.
itay
  • April 27, 2017
And in addition make sure the writer data type and lenght is correctly set.
  • April 27, 2017
Now it works! :) Thank your very much @jdh and @itay!!!
