updating polygon information, with information from another containing polygon
  • September 9, 2013
  • 6 replies
  • 15 views
I have two data sets containing polygons Table 1 and Table 2 (similar to suburb boundaries Table 1 and individual land parcelsTable 2) I want to update data in Table 2 with data from Table 1 when the polygons in Table 2 are contained inside Table 1. The polygon boundaries are not necessarily 100% coincident
something along the lines of update data column when polygon table 2 inside polygon table 1
  • September 9, 2013
the SpatialRelator should be suitable for that task. You can either specify INSIDE or INTERSECT for your test criteria.
David
gio
Forum|alt.badge.img+15
  • September 10, 2013
in 2012 it is either within or contains, depending on the order of your filtering.
If u use intersect u might need to fliter out objects that marginally cross, overlap or touch and are (more ) outside of the objects that are suppose to contain. Unless that's what u want of course.
U can use compound testers  for that.
Or even in the realtor expressionvalues using areacalculation etc.
Lots of options do the same thing.
  • February 14, 2014
In my case I'm working with points, to which I want to add the attributes of its containing polygon (each point has 0 or 1 containing polygons, and there are definitely several hundred points which have a containing polygon).  However on running the Spatial Relator no attributes are added.  I have also tried using the Spatial Filter and the PointOnAreaOverlay and neither of these add attributes either.
Forum|alt.badge.img+5
@paddymas, I had the same problem today and I ended up using PolygonOnAreaOverlayer and a TestFilter with 670K points on 32K grids. My translation picked up 8100 grids without 0 overlaps in 17 minutes. My cardinality was 0 to many points on one grid. Number of points per grid is the overlap attribute of the POAO transformer.
erik_jan
Forum|alt.badge.img+17
  • September 1, 2016
NeighborFinder could do the same.
Use the smaller areas as BASE and the larger as CANDIDATE.
Set maximum distance to 0 and do not treat polygons as line.
  • April 20, 2017
How do you select the smaller area and the largest ?
Thank you
