How to convert 3D Vertex Points to LandXML Cogo Points
I use the template to make a LandXml header but i need to create Cogo Points (CgPoint)
There is a way to make this form 3D Vertex point Creator. ?
Best answer by takashi
Really? This LandXML writer wrote a CgPoint element based on 3D point created by a VertexCreator.
Forum|alt.badge.img+19
  • April 29, 2014
I think the LandXML writer converts 3D points to CgPoint elements automatically when writing them.
Takashi
  • April 29, 2014
No, If i put a LandXml Reader and put it in a LandXml Writer its work.
But if i try to make CgPoints from another source (VertexCreator) its not look to work
  • April 29, 2014
  • April 29, 2014
Ok its works!
  • May 1, 2014
Its it possible to create Groups Points :
Normaly Group points are made with CgPoints Names
<CgPoints name="GROUP_01">
  <CgPoint pntRef="1"></CgPoint>
  <CgPoint pntRef="2"></CgPoint>
  <CgPoint pntRef="3"></CgPoint>
  <CgPoint pntRef="4"></CgPoint>
</CgPoints>
<CgPoints name="GROUP_02">
  <CgPoint pntRef="5"></CgPoint>
  <CgPoint pntRef="6"></CgPoint>
  <CgPoint pntRef="7"></CgPoint>
  <CgPoint pntRef="8"></CgPoint>
</CgPoints>
  • May 2, 2014
A possible way to group the points is to use format attributes called "landxml_***", but I was not able to find how to add attributes...
