Setting the option 'Remove Source XML Attribute' to 'yes' within the XMLXQueryExtractor transformer only clears (but doesn't remove) the attribute.
It would be nice if the behaviour would be similar to an 'AttributeRemover' transformer, that truly removes the attribute from the 'set of exposed attributes'
