Postgres writer: is it possible to add a sql function to an attribute?
  • December 13, 2019
  • 10 views
giosp
Hi to all,
I'd like to add to my insert procedure a specific sql function for example add a to_tsvector(my_column). I've tried to add it in different manners but the result is always my value with the function name written in the column. Is it possibile to do what I want with a writer or I have to use an SQLExecutor and write my desired insert statemenet?
Thank you
Forum|alt.badge.img+48
You can add a SQL query to be executed before or after writing (that's in the Navigator under the advanced writer parameters)
But that's on a per-run basis, if you want to do something per feature a SQLExecutor is probably the way to go.
giosp
  • December 13, 2019
Thank you for your reply. What I like to do is:
insert into tsearch (label,layer_name,role_id,public,ts,geom)
values
('@Value(name)', '@Value(_layer)', 1, trueto_tsvector('@Value(name)'), geom)
With "sql to run before/after" is not possible.
I will use SQLExecutor.
