I have created the relationship (1:1) manually in ArcPro as the relations can’t be created using FME.
The relation is one to one and needs to be done by Title_Number field.
I have also created the relevant fields after reading the article above, here is an screenshot of the AttributeCreator:
Here is an screenshot of the relationship in ArcGIS:
Also here is an screenshot of the FeatureWriter settings to write the relation in the template GDB:
And finally the error in FME after trying to write the relation: Attempting to write a non-relationship feature to relationship class 'rel_NPS_CCOD'. Ensure the 'geodb_type' is set to a valid relationship class type
Any idea how to make it to work?
Thanks
Best answer by nielsgerrits
I think the relation info need to be written to the secondary table.
I have been playing around with the workflow and was able to simplify the workbench to isolate the issue. I complete the exercises in the following article https://support.safe.com/hc/en-us/articles/25407490028813-Writing-Geodatabase-Relationship-Classes which helped me a lot! I was able to create a very simple workflow to create a relation between a Feature class and a table and worked fine :) (….the gdb relation had to be created in ArcPro before running the workbench).
Then...I tried to replicate the same with my project data and doesn't work for some reason. I still get the following error at the end of the FeatureWriter. The Feature class and table write ok but the relation fails: ‘Missing required attribute 'geodb_rel_origin_oid' for writing relationship. Please specify this attribute on all relationship features to be written’
Why fails with ‘geodb_rel_origin_oid’ attribute while has correctly been set up?
Here is an screenshot of the workflow:
Attached the workbench and the template GDB that I use for my translation,
PD: I wish I could provide the data but it is too big
I think you should not write to the relationship class when writing to 1:M, but to the related table, and FME does the writing the the relationship class under the hood. But I rarely do this so I am not very sure. Writing to a relationship class is only needed when writing M:N.
Thansk @nielsgerrits I have changed it but keeps failing with a different error this time, see below:
I have a attached a new version of the workflow in the case you can have a look, the relation info goes into the secondary table (CCOD_Full_Year_Month) but FME doesn’t like it,
Thanks @nielsgerrits I have been able to make it work. You were right, there’s no need to write the relation in FME. I basically created the 1:1 relation in ArcGIS and then use the FeatureWriter to populate the Polygon and the related table. Then ArcGIS will do the rest for as the relation is created already.
