Am sure am missing out some step or obtain right setting. I am trying to extract points that fall inside or intersect 3D Cube .
I am also getting points as an output that are not within 3D Cube .
Please note: 3D is cube is multi-surface with different shapes and its IFC file. I shall be highly obliged with FME Community expert to help me with their know-how and expertise to bridge that missing part / thank you for support and time.
