Trying to find a way to find the maximum amount (highest density) of polygons with the rule
the polygons must be non-neighbouring. Essentially selecting a polygon and jump to the next polygon which is not neighbouring and so fort and so on until you encounter a neighbouring one.
Especially the Color scheme: Map coloring. It should give a color id per group
This is a part off some clustered polygons:
And this whole workspace took 15.6 seconds at my side to complete so I find it a very convenient fast way for clustering (most time is taken up for reading/writing & topology building)
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
