The S3Connector doesn't let me enter a bucket name manually, what's the trick?
  • May 2, 2024
  • 48 views
bruceharold
Forum|alt.badge.img+17
I’m attempting to access an AWS marketplace free resource, NOAA’s bathymetry, but with Anonymous access if I enter us-east-1 as the region I cannot manually specify noaa-bathymetry-pds as the bucket and I cannot get a picker, or not that I can see.  Is there a trick?  Thanks.
Best answer by bruceharold
It turns out things have changed at FME 2024, using the advanced selector worked.
Thanks to the Safe team for pointing this out.
bruceharold
  • May 3, 2024
