How to write several dwg files to new created folder from PythonCaller
jaygrg111_
Hello everyone,
I am converting several SDE geod to respective CAD files. All CADs need to be written in the same folder (with suffix of the currentdate). I  created this folder in Python Caller. How can I now route CADs to this folder?
joepk
Forum|alt.badge.img+20
  • March 11, 2024
Hello,
FME can automatically create folders for you, if you write to ...\new_folder\test.dwg the ‘test.dwg’ file will be written in the newly created folder ‘new_folder’. You can also use a Date/Time function to create a folder name:
...\new_folder_@Left(@DateTimeNow(),8)\test.dwg
This will write ‘test.dwg’ to a newly created folder called ‘new_folder_20240311’
If you want to stick to the PythonCaller approach I would try the following:
  • Use the PythonCaller to create a feature with the path to the folder you created.
  • Merge the path onto the features you are writing to your DWG.
  • Use the attribute in your DWG FeatureWriter to dynamically write to the folder you just created.
If you need help with any of the steps, let me know.
jaygrg111_
  • March 15, 2024
Hi @joepk:- thank you!
I am now using Feature Reader to read multiple geod. I used Feature Writer (output format as dwg) to create the new folder named as current date and year.
What transformers can I use in between these two to export the dwg files to the above created folder with their same name as in the geod? Any suggestion is highly appreciated.  Thanks
jaygrg111_
  • March 16, 2024
jaygrg111_ wrote:
Hi@joepk :- The issue is resolved. But thank you :)
