After scheduling a FME-Server job I want to try it out if everything runs as expectet. If I run it with "Immediately" checked, my previously set date and time settings are overwritten with the time at the given moment I run the scheduled task.
An option to run the scheduled job once on demand without affecting any settings would therefore be nice. Similar to the windows task scheduler option to just run a task on demand.
