I would like to extrude footprint which is available in Shape file till Building roofs, But extruded buildings are above the given building roof, Even I am not able clip the extruded buildings. Any suggestions and solutions if any?
Best answer by daveatsafe
Hi @aruja2000,
Would extruding down instead of up from the roof lines help? You can do this by using a negative extrusion value.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
