Happening in Parent just before Workspace Runner
Excerpt from log:
WorkspaceRunner_2: Running FME Workspace E:\\supply\\Standard_Supply\\SQL_Server\\10km_Buffer_to_SQL_Supply/SQL_Server_County_10K_Buffer_Supply.fmw with command line:
2023-07-25 16:30:02| 1.0| 0.0|INFORM|WorkspaceRunner_2: {C:/Program Files/FME2021/fme} E:/servername/Standard_Supply/SQL_Server/10km_Buffer_to_SQL__Supply/SQL_Server_County_10K_Buffer_Supply.fmw --INPUT_POLYGON E:<backslash>supply<backslash>Common_Dependencies<backslash>Esri_Shapefile<backslash>10k_Buffer_Local_Authorities<backslash>COUNTY.shp --QUARTER 2023Q3 --OUTPUT_COORD_SYS IRELAND-ITM --SQL_SERVER_BACKUP {\\<backslash><backslash>servername<backslash>e<dollar><backslash>SQLData<backslash>CountyCouncil<backslash>ITM<backslash>2023_Q3<backslash>COUNTY<backslash>2023Q3_COUNTY_ITM.bak} 16:30:05| 1.0| 0.0|WARN |WorkspaceRunner_2: Failed to run workspace E:/supply/Standard_Supply/SQL_Server/10km_Buffer_to_SQL_Supply/SQL_Server_County_10K_Buffer_Supply.fmw -- Trace was:
FME 2021.0.1.0 (20210404 - Build 21313 - WIN64)
FME Database Edition (node locked-crc)
Temporary License: 189 days left.
Machine host name is: OSIHP2SUP
Operating System: Microsoft Windows Server 2012 R2 Server 4.0 64-bit (Build 9600)
Copyright (c) 1994 - 2021, Safe Software Inc.
Safe Software Inc.
INFORM: FME_END_PYTHON: evaluating python script from string...
ERROR : Python Exception <FileNotFoundError>: [Errno 2] No such file or directory: ''
ERROR : Error executing string `import sys
import fme
import fmeobjects
import webbrowser
import urllib.request
import base64
