I have several shapefiles in different UTM coordinate system. I want to:
a. reproject each of them into LL84
b. Then merge the re-projected feature into a single shapefile
I need help in
a. Merge features after reprojecting them.
b. Find a better way to do it than the way I am trying to do it (see image below). As you can see, I am stuck and I do not know how to do the last part.
