DGN to Revit Workbench (for Placing Rebar)
jp12212
Forum|alt.badge.img+4
I have an issue trying to get a DGN file into Revit for placing rebar and steel detailing.
I've tried the following:
  • Import an IFC from designer - model breaks and has strange behavior.
  • Convert DGN to a DWG file via FME and import to Revit - broken model no resembling original.
Has anyone developed a workflow or know a good way to achieve a stable DGN to Revit workflow maintaining most of the original integrity without bugs etc.?
Thank you!
Be the first to reply!
