Why do I get FME_SUCCESS == badLuck
jackfanzhang
Hi, I'm using the latest FME desktop workbench version FME(R) 2022.2.0.0 (20221103 - Build 22765 - WIN64)) to convert IFC to GIS. For some IFCs files the workbench failed at the last step to write to the geodatabase, then the workbench gets terminated. The error is
Internal error running translation
Postcondition: Expression: FME_SUCCESS == badLuck
I'm wondering what it means? thank you.
Full error log attached below:
Feature output statistics for `GEODATABASE_FILE' writer using keyword `IFC_Process::IFC_Process_FeatureWriter_0':
                Features Written
DP_320ELGE00__GCLR_DC_320BDAR02_MD3_0001                  13
Total Features Written                           13
FME Session Duration: 5.2 seconds. (CPU: 3.5s user, 1.1s system)
END - ProcessID: 18100, peak process memory usage409132 kB, current process memory usage370420 kB
Internal error running translation. Postcondition: Expression: FME_SUCCESS == badLuck
Program Terminating
Translation FAILED.
kailinatsafe
Forum|alt.badge.img+21
Hello @Jack Zhang​, thanks for posting! I briefly chatted with our development team and they believe you may be encountering a bug. To move forward, consider sharing a workspace and sample input dataset so we can try reproducing this error. Also, may I ask what version of FME Desktop you're currently using? If you're unable to share data on the FME Community, please consider submitting a support case with us so we can help further! Happy to help, Kailin.
virtualcitymatt
Forum|alt.badge.img+34
Excellent error message. Right up there with "ERROR: This should never happen, I swear!". ​ I hope you get to the bottom of it.
hkingsbury
Forum|alt.badge.img+51
  • December 12, 2022
Can't forgot this Esri classic
437231_GeneralFunctionFailure
virtualcitymatt
Hahah, gold
virtualcitymatt
Hey, I just got the ERROR too ha. Also working with IFC.
jackfanzhang
  • May 23, 2023
LOL
charry
  • September 20, 2024
I also encountered it, has this problem been solved?
