Transpose and Aggegate the JSON body data extracted
abnan0001
Forum|alt.badge.img+7
Hello Experts..
I need your Guidance and Help..
would like to transpose the information available in the FME template i have attached ..
In attribute Keeper Transformer - I have 2 fields name JSON index and Data ..
I want to JSON Index in Row as heading and Data is its corresponding Value..
I have attached workspace ..
Also , I have tried to follow this Article " https://community.safe.com/s/question/0D5Dm000006Zdi5KAC/transpose-a-table"
I want to transpose this and aggregate it
imageThe results Comes in this way
Kindly Support and Guide
Thank You
abnan0001
  • April 10, 2023
Hello Experts
Any Guidance to the query posted to transpose the attribute.
Your suggestions highly appreciated
Kindly guide
Thank you​
hkingsbury
Forum|alt.badge.img+53
  • April 10, 2023
You've basically got it in your last screenshot. Now you need to run it through an aggregator making sure you merge all attributes
depending on how much data your pivoting (expecting more than one output row) you may need to set the groupby to an attribute that will group the inputs into their expected outputs
