Converting a CSV File Loaded as an Attribute via SharePointOnline Connector to a Temporary Table for Transformation
renosungis
Forum|alt.badge.img+3
Dear FME Community,
I am facing a challenge while using the SharePointOnline Connector in FME to load a CSV file directly as an attribute. My objective is to avoid storing this CSV file on any network drive, local drive, or an M365 named account OneDrive folder. Instead, I'd like to process it immediately within the FME workflow.
Goal:
My end goal is to convert this attribute—which contains the entire table from the CSV file in text form—into a temporary table or a temporary CSV within FME for further transformation.
Version:
I am currently using FME version [2022.2.0.0 (20221103 - Build 22765 - WIN64) ].
Problem:
I can successfully load the CSV file as an attribute (see picture), but I am struggling to convert this attribute to a format (temporary table or temporary CSV) that I can then transform further.
SharePointOnlineConnector configuration loading CSV from SharePoint Online
_contents loaded from sharepoint online .csv
Questions:
How can I convert an attribute (_contents) containing a full CSV text file into a temporary table or CSV within FME?
Are there any transformers or specific settings that can facilitate this operation?
Your expert advice and guidance on this issue would be much appreciated. Thank you in advance!
I wish there could be a super easy and effortless way to load CSV and Excel files dynamically and directly from SharePoint Online.
Best regards,
Reno
Best answer by nielsgerrits
You are almost there, add a FeatureReader downstream the SharePointOnlineConnector to read the file. The features will be output from the Generic outputport because the workflow is dynamic. You can expose the attributes using the AttributeExposer, import from FeatureCache.
If you whish to do this without having to remove the downloaded files, put a TempPathNameCreator upstream the SharePointOnlineConnector to save the file to a temp directory.
nielsgerrits
Forum|alt.badge.img+53
  • September 1, 2023
renosungis
  • September 2, 2023
Hi @nielsgerrits ,
Thank you so much. I just upgraded to FME Form 2023.1, and I found they make it super easy to load any web files from SharePoint Online using "Select File from Web"!!!
Select File from WebMaybe this feature has been here for a long time...I should have noticed it.
I am very thankful for your solution, and it will come handy in the future when I have to convert text based data into a temporary table.
BTW, our profile pictures are both from Sesame Street lol 😆
Sincerely,
Reno
nielsgerrits
Learned something new today :) cheers.
