I have some data that i am trying to replicate from 1 DB to another, but I cannot create the readers for several FCs that contain arcade expressions. I get the The error number from ArcObjects is: '-2147211773' message. I am running FME 2021 (64 bit), and have ArcPro installed and the Esri ArcGIS Capability is set to Pro. One thing I can't seem to get is the ArcPro Python listed under Python Compatibility. But I do see that listed in FME 2019 on the same machine. Any thoughts on whether or not this should be working and if so, how I can get it to work?
Trying to read Enterprise GDB data that includes arcade expressions / attribute rules with FME 2021
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
